Diagonal Wall
Diagonal Wall
noenoeTRQJM
Diagonal Wall
noenoeTRQJM
Hi, I am a newbie to Revit. How do I manage the diagonal wall, which seemingly not connected to the beam. I use tool "Join Geometry" and it is not working.
Ramina_B
Is the column a structural one?
vitorbortoncello
Do you wish to extend the wall? use Extend
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
noenoeTRQJM
I've tried. I guess it can only use for walls.
noenoeTRQJM
No. It is the Archi columns.
jay_colc
Try using the same material for all elements
Also review the Join Tool as you can Switch orders
Jay Colcombe
Autodesk Certified Instructor
Ramina_B
If nothing work you can use cut profile, but be aware that it's only a 2D solution...
