Determine the Axis or Center of Rotation
Hi everyone,
Using revit I can modify->ROTATE the walls around default axis/center or I can also drag the axis somewhere else and can rotate the wall around it. This is all good.
Is there any way that my plugin can read this information using REVIT API C#? For example:
- I have the initial position of a wall (w1).
- Now user rotates the w1 using REVIT controls
- So is there any way to get the values that what was the rotational axis (rotation center) and what were the first and second ray values (basically angle)?
L.Maas
Sorry, can not help you here. You might try to post your question in the Revit API group. More chance to find people there who can give an answer.
Louis
Please mention Revit version, especially when uploading Revit files.
Oh thanks Louis. i didn't know this before hand. Just posted in that group.
Thanks anyways.
