Detect walls with modified profiles
Message 1 of 30
I'm tasked with auditing a model we've received and a lot of the walls have modified profiles. I was wondering if it is possible to somehow select all the walls that have a modified profile and none of the regular 'rectangular walls?
I do have Ideate Explorer at my disposal, but could not find this particular parameter.
Replies (29)
Message 21 of 30
@ToanDNIf anything I think it is because we are using an older version of Dynamo at the office (2.0.3.0, core 1.3.4.6666).
I used Revit in English today, uninstalled all packages and reinstalled all the newest: same result.
The only thing I can think of that is not in order is the old Dynamo version.
Message 22 of 30
My Dynamo version is the same as yours (2.0.3.0, core 1.3.4.6666) and it runs fine.
Can you share a screenshot of the warning popped up on the nodes after an execution? They will tell you what the errors are.
Message 23 of 30
@ToanDNThe main problem is that I cannot ge the node to show up at all to even put it in a formula. When I search for SPRING, nothing comes up. If I understand correctly, I need the 'Springs.collector.ElementSketch', but I cannot obtain it.
Also, when I install Springs, it tells me that it is using a newer version of Dynamo, which is why I was thinking this was the problem.
Message 24 of 30
Yien_Chao
i start with the idea of section profil of wall not elevation Profile (what you are looking for in presume).
it has to be by the RevitIFCDLL librairie.. i'll check and let you know.
Message 25 of 30
Yien_Chao
ok let's resume.
i made a python to get ONLY walls modified manuallly.
The IFC.ExporterIFCUtils.HasElevationProfile() is the function to use.
basically, if you look a the image, only the last 2 will be output, the others modification are drive by another element.
Message 26 of 30
@Yien_ChaoThat is exactly what I am looking for. I basically want to catch every time users made a sketch, because I consider it bad practice (bad for wall joining, level relationship, etc). This is for my model audit workflows.
Message 27 of 30
Yien_Chao
try this 🙂
# Yien Chao 2019
import clr
#IFC.ExporterIFCUtils
# Import DocumentManager and TransactionManager
clr.AddReference("RevitServices")
import RevitServices
from RevitServices.Persistence import DocumentManager
from RevitServices.Transactions import TransactionManager
from System.Collections.Generic import *
#import ifc dll
clr.AddReference("RevitAPIIFC")
# Import RevitAPI
clr.AddReference("RevitAPI")
import Autodesk
from Autodesk.Revit.DB import *
uiapp = DocumentManager.Instance.CurrentUIApplication
app = uiapp.Application
doc = DocumentManager.Instance.CurrentDBDocument
collector = FilteredElementCollector(doc)
filter = ElementClassFilter(Wall)
elements = collector.WherePasses(filter).ToElements()
OUT =  [i for i in elements if Autodesk.Revit.DB.IFC.ExporterIFCUtils.HasElevationProfile(i)]
Message 28 of 30
Hi @Yien_Chao, this comes out as NULL on my end in the Watch window
Using Revit 2019.2 and Dynamo 1.3.4.666
Message 29 of 30
Yien_Chao
can't say..i works fine here.
send your revit file?
Message 30 of 30
Yien_Chao
Oh im on Revit 2020 and the latest dynamo.
