Revit 19 - I can't find the fiberglass insulation section in my details library - only insulation in the library is rigid.
Duh...I've been very tardy in upgrading versions so i had to upgrade to 19 ...put it on the ribbon... how convenient.
Thx!
What is fibreglass batt insulation?
Fiberglass consists of a fine glass-like thread that makes sure that provides thermal resistance and keeps your home temperature balanced. The insulation is installed in pads, that are placed in between your studs, trusses, and joists, and then covered with a plastic vapour barrier to make it effective. The vapour barrier is a key component of the insulation system and should be done by a professional to ensure your house is properly insulated, to ensure you have no leaks and drafts flowing in and out of your house.
For more Details visit Spray Foam Masters
