Detail views rotated after DWG Export
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi All,
I'm creating a Building Section for a particular element in my model (Grid 9A - Eje 9A):
Structural Plan for 2nd story
Building Section for grid 9A
In the Building Section, I created a Detail View which contains the details of rebar configuration:
With this information, I created my deliverable Sheet, containing all views mentioned before, and play with the viewports sizes and locations:
My issue starts with the DWG export. In AutoCAD, I realize that in Layout 1, the viewport containing Detail VIew "Corte 9A-1" is rotated. I need to deliver to the client the Revit Model but also PDF and DWG files, and I don't want to go 1 by 1 of the sheets rotating the Detail views.
Layout 1 in AutoCAD
Model in AutoCAD
So:
Is there a way to avoid this?
Why is this happening?
What am I doing wrong?
Any tip of advice or recommendation for a different approach to doing the task will be very well received.
Thanks in advance!
