Detail number conflit
9 REPLIES 9
Message 1 of 10
ianmotabr
592 Views, 9 Replies
Hi all, I've a section viewport to place within sheet, but when I try rename the viewport the Revit error out "Detailing number is already in use", however the Referencing detail don't exist.
9 REPLIES 9
Message 2 of 10
CanutoDesign
in reply to: ianmotabr
This is referring to the Detail Number ... make sure this is a unique number in the Properties window
Message 3 of 10
Do you want to reference that other view?  If so, check "Reference Other View" and select that View in the drop-down list.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Revit-D....)
Message 4 of 10
ianmotabr
in reply to: CanutoDesign
So, the Detail number in sheet is unique. But the "Reference view" (below in properties colum) exists and I don't understand why that happens
The viewport is in no one sheet
Message 5 of 10
ianmotabr
in reply to: barthbradley
I can't rename the Detail Number property to a specific number
Message 6 of 10
Go to Sheet 122 and rename it then.
Message 7 of 10
Referencing detail number has nothing to do with what you are trying to do.  Expand the list of views on the sheet via the sheet browser and there must be one view with number 1.  Renumber it to something else then you can change your detail view to number 1.
Message 8 of 10
Go the Sheet 122 and rename it ("it" being Detail Number: "1").  Bada bing.
Message 9 of 10
ianmotabr
That's the problem, the section viewport not within a any one sheet.
Message 10 of 10
ianmotabr
in reply to: ToanDN
Thanks! That's worked!
