Detail components lines under 3D categories lines
How can I do if want the details components or detail lines always under 3D model categories lines? in Plan or section view.
Hi Omar,
Details are designed to be over the model geometry.
Details themselves can be controlled using Draw Order (on the Ribbon) when they are selected - but this will not push them behind model lines.
You can override the model geometry to hide what you don't wish to see e.g. the cut pattern in a wall for example. Then place your detail component, repeating detail or detail lines over the top.
You can also use the Linework tool fro the Modify tab to override existing lines and change them to another style. (there's even an invisible type)
If you are using a detail component and it's completely obscuring the model geometry and you do not want that. then you can edit the components Type and switch its  background to transparent as well.
Hope that helps
Justin
Jsmy91
Hello!
I would really like to know if this is possible now, I am currently modeling a lot of public space and here is one of my usual problems with this.
A Lighting Fixture (3d Family) being showed under the Tactile Tile (Detail Item)
Yes. Create the tactile item as model family or even in place model family and draw detail items in the family.
Jsmy91
Thanks for your answer ToanDN, it actually worked. But I still have some issues with it.
1 If I use this 2d Generic Model on a Sloped surface it is swallowed by it.Tactile tile on Generic modelTactile tile on Generic model
2 If I add a little bit of offset to the Tactile Tile in Generic Model, it generates shadows. Well, this is not so bad, but I will have to turn off the shadows for my plan view or play with the Azimuth and Altitude
Tactile Tile with offset but  casting shadowsTactile Tile with offset but casting shadows
Azimuth 180, Altitude 0Azimuth 180, Altitude 0
Thanks a lot again, I hope someday we can have more control about the foreground/background thing in special for high detailed views.
In such case, I would create it using a face based family so that you can host it on a slope surface or a reference plane in project.  And you have to use model lines or nested generic instead of detail components to draw the graphic.  It would be even better if you can use a material for it.
Below is an example of a loading area and a curb cut domes on a slope, works for both 2D plan and 3D view.
Capture1.PNGCapture.PNG.
