Desktop Connector
Desktop Connector
paul.eterovichY6MNN
Message 1 of 1
Desktop Connector
paul.eterovichY6MNN
https://help.autodesk.com/view/CONNECT/ENU/?guid=Versions-retiring-2025#what-happens-if-i-do-not-upd...
It says in the above page that users should "Run the DC Reset Utility for v15.x for best results." when installing the new 16.x version of Desktop Connector if their current installed version is a 15.x version.
What does the DC Reset Utility actually do? Is it going to cause havoc with the files already in Autodesk Docs on a users computer? Will they need to be recached after this process?
Thanks for any insights you may have.
Replies (0)
