Designing the table description in Revit default sheet.
Hi, I have problem when try designing the table above. I want to add some words into the empty box but I can't do it. when i double click to the box, I trying to figure out how to add some words but all failed. Can someone help me please? Thanks you
constantin.stroescu
I would use a Note Block ( from Schedule) for this...
  • make first a Generic Annotation Family.
  • Here you create a Label
  • Create 3 Text Instance Parameters: No, Description and Date
  • from these 3 Parameter, only No will be load as Label Parameter
  • Load Family into the Project
  • Place this Generic Annotation Family as instances somewhere in the drawing as many number needed and allocate numbers ( 1, 2,...n as many needed in your table), then type values in Description and Date
  • for further information on the subject , see AKN ( Autodesk Knowledge Network)
Constantin Stroescu
loboarch
That table is actually a "revision schedule" and designed to work specifically with the revisioning tools in Revit.
http://help.autodesk.com/view/RVT/2021/ENU/?guid=GUID-0F2A9A13-0A88-4D18-9DF7-C0296DE0FFE4
Jeff Hanson
Principal Content Experience Designer
Revit Help |
thanks, that really help me.
