Designer II
Designer II
Designer II
I link a cad file into revit its shows in the overall floor plan but not in the enlarged floor plan. I'm using revit 2019.
Anyone can help me?. Thanks in advance
Redrunner92
When you first inserted the linked file into Revit, did you check the box which says "Current View Only"?
Current View OnlyCurrent View Only
Have you checked your Visibility/Graphics menu to ensure Imported Categories, and that particular CAD file, are visible in your enlarged plan? Is a view template's settings (particularly the Imported Categories tab) precluding the appearance of the CAD file?
Is the CAD file on a level which is outside of the View Range of the enlarged floor plan's view?
Just a few ideas to start. Let us know if none of these are the source of the issue.
...another possibility: placed on level that is not within the view range.
Redrunner92
Can you post a couple screen shots: one of the overall plan where the CAD file is visible, and one of the enlarged plan where it is not? Be sure to include your Properties palette in both images.
...my money is on "Current View Only"
Redrunner92
That's likely it. Though just for fun I'd put money on the view range being too narrow.
