Design Options: Room tag can't add to set
LanggamanXavierMassed
Is there any way you can view a room tag only on a specific design option?
Thank you!
bin
Yes, you can have different rooms for different design options, as well as room tags.
A short video I did a while ago...
ooh thanks but can you hide only that room tag you immediately put on main model in option 1 view though?
the room tag i did was first done in main model and i couldn't transfer it to option 1,,
i did that because my option sets are completely different in layout not just some parts
so yeah i just had to delete it from main model and redo it to option 1 so it won't be seen in option 2, thanks btw
bin
You can also select the room and click on this Annotation 2019-07-27 213729.png
This will allow you to delete the room from the main model, and move it into any option you ticked.
I'm reading this and wondering if you are aware that you can set up Views to display specific Design Options.  To do this, go to the Views Visibility/Graphics Overrides=>Design Options tab and change "Automatic" to the name of the Design Option you want to be displayed in that View.
