Design Options back to Main Model
I am trying to add design options back into the main model. Is there a way to do this without deleting the options?
I have a wall that I need to join, but I can't join them because one wall is an option and the other is not. I no longer need the wall to be a design option. How do I remove the wall from design options and put it back into the main model?
I don't want to delete the wall and start over.
rodrigo.bezerra
Unfortunately I can't test it right know, but I think you can cut and then
paste it aligned to same place, from an option into the main model.
Regards
Rodrigo Bezerra
Thank you. That seemed to work.
You would think there would be a more straight forward way, like a "remove from options" button or something, but I haven't found one yet.
