- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- パーマリンクを表示
- 印刷
- 報告
When I changed a Design Option to primary, a handful of errors popped up. Most of them I anticipated, but these errors about Legend Components are baffling me. I don't have Legend Components of any of these walls in a Legend. Also, since I cannot use the given ID #s to select objects, I am guessing these IDs refer to wall Types and not wall Instances. Does anyone know why errors about Legend Components are appearing, especially errors of the magnitude "must be addressed"?
Further info:
When I made the selected option primary, Revit duplicated a bunch of wall and floor types "to avoid duplicate names." I promptly deleted these unneeded duplicate types. Before I exited the errors menu, though, I noticed that these duplicate types are what the errors are addressing (note the "2" suffix in the wall type on the shown Legend Component error). This process of duplication may be a hint at what is going on to generate these un-ignorable errors. I don't know why this whole process of duplicate-then-cause-errors is happening.
A handful of errors regarding Legend Components which have no instances in the project
I cannot use the element IDs to select anything. This leads me to believe these IDs belong to Types of walls rather than Instances of walls.
解決済! 解決策の投稿を見る。
