Design Option elements not exported to IFC
adamskaEXHPY
Message 1 of 8
adamskaEXHPY
Hi there,
I have an issue when exporting an IFC - the facade, which is not a primary Design Option, doesn't show.
I am exporting "only elements visible in the view" and there is the desired option assigned to the view.
I have never had an issue exporting IFCs, with or without Design Options.
What am I missing here?
Thank you
Replies (7)
Message 2 of 8
Did you activate the DO on the View Control Bar?
Message 3 of 8
adamskaEXHPY
Not when exporting - the DO is set to "Main Model" but I have the desired option assigned in V/O.
Message 4 of 8
IhsanGinBaker
Did you check the ifc export options to see if the design option includes any classes that may not be set to be exported?
Message 5 of 8
stefan_gokstorp
in the ifc setup set create geometry from visibile in view should work.
Message 6 of 8
adamskaEXHPY
It's a simple facade with just walls and doors - these are visible inside.
Message 7 of 8
adamskaEXHPY
It doesn't - that's why I am here... 😉
Message 8 of 8
stefan_gokstorp
not export objects visibly in view.
Use active view when creating geometry.
