depth cueing in perspective views
jagostinho74
jagostinho74
Is it possible to enable depth cueing in perspective views?
It is always greyed out.
Thank you
J
Assistant BIM/CAD Manager
Manchester, UK
Sections and Elevations only
Perspective views themselves give depth perception.  Why do you need Depth Cueing?
MostafaElashmawy
Not applicable.
Mostafa Elashmawy
constantin.stroescu
You can use a workaround:
  • in a Site View or the Perspective View, select the objects from the background that you want to show with thinner lines or halftoned.
  • make a Selection Set named somehow
  • in Perspective View , Load the Selection Set made before and use Override by Element to change the Line Appearance
  • Repeat the steps for other objects placed at a different distance from the Camera
Constantin Stroescu
ruxandrabogdan
Community Visitor
Community Visitor
for colours (when is not in Realistic style)
