depentent views and scope boxes
b.aarntzen
Message 1 of 10
b.aarntzen
hello everybody,
I want to create a number of dependent views of a certain elevation and assign a scopebox to the views. Creating the dependent views isn't a problem but assinging them a scopebox is. I've tried a elevation and section view, both don't work. In a floorplan I can still assign a scopeboxe to a dependent view.
In 2022 this wasnt an issue but i found out i cant assign them in Revit 2023. Is it something Autodesk has changed or am i missing something?
Replies (9)
Message 2 of 10
hansbroeksteeg
Same issue here. We installed the latest update version, but we're not able to assign a scope box to a dependent elevation or section view.  This wasn't an issue in Revit 2022. Is this a bug in 2023??
Message 3 of 10
d.ahmed.LW
Is it greyed out in 2023 or the option is not available at all?
Message 4 of 10
hansbroeksteeg
it's greyed out
Message 5 of 10
d.ahmed.LW
Is your crop Region Visible option ticked on?
Message 6 of 10
hansbroeksteeg
We tested this and it didn't make any difference. Either way, Scope Box remains greyed out.
Message 7 of 10
Scope box doesn't work for dependent elevations and sections because it is not at the view cut plane.  Are you sure it works in 2022?
Message 8 of 10
hansbroeksteeg
Thanks for thinking along.
Yes, it works in Revit 2022. We used a project from 2022 en translated it to 2023 to use it as a template to start a new project. No differences in settings between 2022 and 2023.
Message 9 of 10
bjornsluijs
We have the same issue here....anybody the solution?
Message 10 of 10
berndhidding
Still having this issue...
There must be more people with this problem?
