Sorry I am so late in responding. Never saw this question. We typically lay out scope boxes using a combination of a 3d view and foor plan view. Scope boxes are a special 3D modeled area crop that is available model wide in every model view. You do need to turn them on if they are off using visibility graphics. You can create one in a floor plan, then turn them on in a 3D view and make sure the scope box is stretching to capture the height you want. I typically create one, set the depth boundary, then copy it around to other areas and re-stretch. Then I name my scope boxes according to view area (e.g. Area A, Area B etc) Then you can just duplicate views as dependants for as many areas as you have and apply the scope boxes to those areas. Do this for every floor.
Sometimes we use different scope boxes for different floors if we have a different match line per floor (Although we try not to do this). Clear as mud, eh?
Joshua S.
The Freelon Group
Joshua S.
The Freelon Group
