dependant views symbols
DavidRichardson
DavidRichardson
Community Visitor
Community Visitor
Hi, I have floor plan too big to fit on a single sheet, I have split using dependant views. Is there are way I can show the elevation and section markers in both parts of the floor plan. They are only showing on the plan portion where they are contained in the cropped region.  Is there a way of dupicating the symbol or some other suggestion?
thanks
Dave
azad.Nanva
could you send a Screenshot?
ennujozlagam
try matchline and see if helps?
RSomppi
It is normal behavior for them to show where they exist within the crop region. If you need additional sections and elevations, you can create new ones or use the parent view to copy the existing ones from one part to the other.
Use Match Line and View Reference.
