- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is it possible to demolish several elements at once? I have to demo a large chunk of a 5 storey building which will be extremely time consuming if I have to go through each level and click on each element with the Demo hammer individually.
Also, I have created a new project phase so I now have;
1. Existing
2. Demolition
3. New Construction
This file contains a cloud-point survey model which I have linked into my design model. I just want to check that setting up the Demolition phase was the correct thing to do? The project involves merging new construction with existing buildings, parts of which will be demolished. I read somewhere online that creating an extra phase might confuse matters down the line? I don't want to make any obvious mistakes early on.
Lastly, is there a way to reverse the demolition in Revit if we decide that a particular element is no longer being removed?
Thanks in advance for any help,
Rory
