Demo wall is not displaying correctly
tstewart
Message 1 of 9
tstewart
The demo wall is not displaying correctly. How to use the "Demo" hammer, or get the wall on the correct Phase, so that it displays as demolished?
Replies (8)
Message 2 of 9
syman2000
What phase filter are you using?
If you change it to show Demo + New, it should display the demo as hidden line as display in the phasing setting.
Also do you have any override filter? This will override whatever that was display with phase filter setting.
Message 3 of 9
tstewart
The Phase is shown as Demo & None, so I don't see what you suggested.
Message 4 of 9
syman2000
The post I am posting is check those setting and see if you have item that deviate from the default setting. This will cause your demo wall to show as solid instead of hidden.
Message 5 of 9
tstewart
Thank you and the wall is not showing correctly.
Message 6 of 9
syman2000
Upload the file so we can take a look closely.
Message 7 of 9
SteveKStafford
A wall that has been demolished has the following settings: Phase Created "an earlier phase" and Phase Demolished "a later phase". The view that shows the demolished wall must be assigned to a phase that is later than when the wall was created. The Phase Filter should be one that is set to New (By Category) Existing (Overridden) Temporary (Not Shown) and Demo (Overridden).
Steve Stafford
Message 8 of 9
tstewart
Excellent and thank you!
Message 9 of 9
tstewart
Solved and thank you.
