Demo OHDoor/Infill wall/insert windows
Hello guys.
I have a hard time to found a solution to show two new windows infill in the wall after demo the existing garage door.
I tried different phases and join elements. I still don't understand what is wrong. Why two windows coming and the other two don't through the new wall. I hope for your support. Thank you.
Assuming the Windows are Phased correctly (e.g. created in a Phase after the Door is demolished), then set your Phase Filter to Show Complete.
...unless I am misreading you. Sounds like you are saying that the Garage Door (which is cutting the Existing Wall) is Demolished and Windows are then inserted into the Garage Door Existing Wall (which remains after Garage Door is Demo'd).  So basically, the New Construction equals Windows, as well as more Wall.  Am I reading you right?
Select the window and Pick New Host or Pick Primary Host then pick the infill wall.
I left only two phases Existing and New (I tryed new2 etc. the same situation)
The garage door is the existing phase, demolished on New phase
Then Revit makes an autofill wall.
I put new windows phase New,  demolished phase none
Thank you.
Works!!!!
