Deleting dwg import from revit family
AthenMar
AthenMar
Hello, I´m using revit 2019 and I imported a dwg file in a Title Block Family. When I delete this import in the family (by selecting and deleting) I can still see all the autocad layers in the Visibility/Graphics dialogue, but I cannot delete them. When I load the Title Block Family in a project I see all these layers under Object Styles > Imported Categories > Imports in families and I can delete them there, but i would like not to have to do this every time. Is there a way to delete these layers in the Title Block Family? Thank you.
RSomppi
Have tried doing it from the object styles in the family?
AthenMar
Yes, but they do not appear there somehow...
RSomppi
Load the family into a fresh project to see if they come in with it.
Sounds like you exploded it?  Use Purge Unused tool.
Purge All from the family before load it in.
AthenMar
I closed and reopened the family and they are not there anymore so i guess problem solved.
