delete temp files?
delete temp files?
delete temp files?
Currently Revit caches model files to the local My Documents folder which eventually fills up the hard disk. It would be nice to have built in functionality that deletes files older than x days, or if there is a different solution to this problem, what is it?
Just time to time delete them....
Same with C:\Users\<username>\AppData\Local\Autodesk\Revit\Autodesk Revit 20XX\Journals
and
C:\Users\<username>\AppData\Local\Temp
Use Notepad to create a .bat file contains the following code:
forfiles /p "C:\test" /m "*.*" /c "cmd /c del @Anonymous" /D -7
C: is the target drive letter
\test is the target folder
/D -7 is for files older than 7 days
