Delete/Remove Browser Organizations
Message 1 of 15
I would like to delete several duplicated browser organizations I have transferred between files.  It seems the delete button within this dialog is grayed out and does not function.
How can I remove duplicated or unwanted browser organization types from my files. Any help is much appreciated.
Thank you!
Replies (14)
Message 2 of 15
Try selecting something
Message 3 of 15
Selecting something does not enable me to delete it
Message 4 of 15
Alan.johnson1970
Have you tried applying one of the schemes (tick)
select one you want to delete (not tick)
AJ.
Message 5 of 15
Make sure the Project Browser workset is not owned by anyone.
Message 6 of 15
My Browser Organization is non-editable and not owned by anyone.  My inability to delete any browser organizations crosses into my sheets and schedule tabs as well, so I do believe it is being controlled by some global setting.
Message 7 of 15
Maybe it was created by the Template (RTE) that you used?
Message 8 of 15
Open the central file detached and try again.
Message 9 of 15
Highlight it...don't checkbox it.  Whatever is checkbox'd cannot be deleted as it is the active scheme.
Also....if this was a central file, did you detach from central first?
Message 10 of 15
Message 11 of 15
Weird...mine the delete grays out when it is selected.  I can edit or rename but Delete cannot be selected.
I'm using 2019.2...what version are you using?  Checked...my 2020 doesn't allow me to delete active view schemes either.
Message 12 of 15
I see.  I was on 2016.
Message 13 of 15
This solved my problem, thank you.  I am still unable to delete the 'all' browser organization however.
Message 14 of 15
"All" is read-only.  You cannot delete it.
Message 15 of 15
mmartag
I have the same problem. and i haven't figure it out yet either.
