Delete phase filter
Delete phase filter
luizacervi
Message 1 of 14
Delete phase filter
luizacervi
I would like to delete these two phases however, since they are greyed out, I can't remove them. I want to delete them because they are duplicates. Is it possible to remove them?
Replies (13)
Message 2 of 14
RSomppi
Filters get greyed out if they are in use. Find the views/view templates that are using them. Assign the correct filter and then delete.
Message 3 of 14
Are you sure about that?  The only Phase filter that cannot be deleted is Show All.
Message 4 of 14
RSomppi
Did you test it?
 I was cleaning up files when I “discovered” that greyed out filters became available when I stopped using them.
Message 5 of 14
Yes I tested it.
Message 6 of 14
luizacervi
It didn't work. I assign the views and view templates in the "final project" filter and nothing changed, the same filters are greyed out
Message 7 of 14
luizacervi
Message 8 of 14
RSomppi
They are being used somewhere. Views and View Templates are the most likely candidates but I can't think of any other place that they would be used. I would make a view schedule and check there, if you haven't done so already.
Message 9 of 14
luizacervi
Sorry for the images in portuguese (BR). It didn't work, everything is in "Projeto Final" (Final Project) and the philter "Mostar tudo" (Show all) is still graeyd out... I can even delete "Final Project" philter even when it's being used on every view.
Maybe this is a bug? I transfered project standards from another template... I guess that's why there's duplicades... I don't know, do you have any other sugestions?
Message 10 of 14
RSomppi
Stay away from calling anything a bug. 99% of these things can be sorted out.
I'm sorry but there is nothing more that I can do without the model. You need to find out where they are being used.
Message 11 of 14
luizacervi
I don't understand how this can be the solution because, as I said before, I am able to delete a filter that is being used, but I can't delete this specific filters.
I can't share the model but I trully apreciate you taking your time to help me.
Message 12 of 14
RSomppi
It might not quite be the solution for you but it worked for me earlier this week.
One thought that occurred to me is that they are in a linked model. The fact that they are "Show All" tells you that they cannot be deleted so any attempt at doing so is a waste of time, IMVHO.
Message 13 of 14
bwinterscheidt
Download and install the "Revit Lookup" utility, use it to Snoop DB, and find the ID of those PhaseFilters.
Then you can close that app, use Revit's "Select by ID" tool, and press the Delete key on your keyboard.
https://github.com/jeremytammik/RevitLookup
Message 14 of 14
luizacervi
Thank you! That worked!
