Hi
Deleting level is a tedious process to make sure you are not deleting elements attached to it.
A. If the project is small then in 3d view, you can manually select elements one by one or by category and change the
base level ( level you want to delete ) to new level ( the one you want to keep )
B. Keeping walls, curtain walls, columns, unconnected helps the model to move levels without any errors.
( cause they need base and top constraints )
If the project is big, then create a plan view for that level,
so most of the elements visible would be connected/ constrain to that level,
and then rehost, change the base constrains of all those elements to new desired levels.
General elements which are level based
1. Walls ( base and top level )
2. Curtain walls ( base and top level )
3. Floors ( only base level )
4. Roof ( only base level )
5. Mass
6. Column ( base and top level )
you can schedule these categories and change the base constraints in one go as well...
C. Deleting levels will delete anything which is associated to that like
1. floor plans
2. area plans
3. RCP
4. Structural plan
5. dependent views, plans
Best of luck
Cheers!
Corsten
Building Designer
