Default Architecture Template File
jdhF2S5U
jdhF2S5U
I know that there's a default template file that was created by Autodesk in Revit, so I used default template to do a simple working.
However, I recently reinstalled it due to a program error, but the default template is not displayed.
I looked for some help, and I tried various things.
I've tried downloading files using library, contents bundles, custom downloads, and checked the Revit.ini file, but I don't know why I can't see it.
Is there a solution?
Alfredo_Medina
Go to File > Options > File locations > Configure your favorite template there. The first template on this list is what you will see by default.
