Default 3d View wont show entire model - white bar blocking view
gballam
gballam
I have had this problem on several occasions but typically just work around it. It appears that there is an empty white bar that is cutting off my view of half the model - The boundary box is not the problem since it is all there when I rotate it around though. I've attached some screenshots of different angles - please assist!
chadwickt
Good morning!
I think your view is being cropped. Try turning off the cropping with the button shown below. I hope this helps!
Or Uncheck Crop View from properties.
