Default 3D view showing section box in autodesk drive
torbjorn
torbjorn
Hi!
When you upload your model to autodesk drive the default 3D view is cropped like it is in Revit model. Is there a way to upload the model with no section box even though it is applied in the default 3D view?
Otherwise i need to unbox section box in the default 3D view everytime i save and exit a model. I have very many models that i work with so its quite annoying. (See picture for an example)
I have allready tested to create a new 3D view, but the problem is when you work with the model and press the shortcut for section box "SB" it creates the SB in the default 3D view.
Any ideas?
Reed_Weinstock
If you want to create a 3d view without the section box turned on by default you need to create a new 3d view not a section box
torbjorn
Hi and thank you for the answer.
Autodesk drive viewer only show´s  the default 3d view, so if you have multiple 3d views it´s not gonna display as a view in autodesk drive. So it does not really matter if you create one more.
You could work in the new 3D view (not the default) but when you use the shortcut "SB" (Section box) it enters the default 3D view and not the new view you recently created and i rather use "SB" in this case.
