Deck plan view range issues - can't see walls
cbt990
cbt990
The units are visible due to Underlay from level above.
You can see in section the bearing walls do extend to the bottom of L3 slab.
Level two shows what needs to be visible on L3, as an underlay or halftone.
Revit is amazing
cbt990
I can see the analytical model if I turn on analytical walls.
Revit is amazing
Your Level 3's view range bottom and depth must NOT extend to Level 2 in order to show Level 2's elements as Underlay on Level 3 floor plan view.
