Data in file is corrupt and needs to be manually recovered (help)
ymolina2Y8AC
Observer Observer
ymolina2Y8AC
Observer
Observer
Hello.
I am using the "IceDrive" storage option for my files and I am suddenly not able to open my files due to an error message (Data in file is corrupt and needs to be manually recovered) can anyone advise on how to proceed?
BDMackey
Not sure about IceDrive but many cloud solution don't work well with Revit, if there is a glitch during any part of the opening, saving process then it will give you this error.  You can try to open the file with Specify Worksets and close all the worksets, I doubt that will work but worth a try.  If not all you can do is go to a back up and restore, or send the file to Autodesk and wait for them to repair.
