- Mute
- Permalink
- Report
Above you see two views, V1 and V2. They both contain the same group, the only difference is one has an additional island next to it... Both views also have the same view template applied. There is no linework tool overrides. Yet, for some odd reason, the upper cabinet casework dashed line masks the counters solid line in V1 view but not V2... I can make the counter solid line appear by making the upper cabinets not directly of top of it... I have had this happen to me once before with another family, but at the time ignored it by doing the offset trick. Now that it happened again, I am curious if any one knows what the issue is? (Tried printing using various PDF printers - same issue, problem seems to be Revit or my workflow)
