Cylinder with void extrusion
_damien
_damien
I'm trying to create a cylinder family with a void extrusion. I created an extrusion and linked a parameter to it. after that, I made a void extrusion with a parameter so the void's diameter is 1/8" less than the cylinder's diameter. However, when I link the void diameter to the parameter I get a waring that the constraints are not satisfied. I can't figure it out what is wrong.
Thank you for your help
Alfredo_Medina
Instead of doing a cylinder with a void inside, do a tube. In the same sketch, do an outer circle and an inner circle. Simple.
_damien
Thank you Alfredo_Medina.
I have the same issue by doing a tube. I don't understand what I'm doing wrong.
Thank you,
