Cutting multiple Topo Surfaces with a Pad, or how?
bdeioma4XX55
bdeioma4XX55
I have a model in 2023 that has several (18) topo surfaces. The pad might be cutting one. But I'm not sure. Is it a thing that Revit pads only cut one Topo?  What is recommended to cut into a multi surface topo model?  Thanks.
vitorbortoncello
Place a building pad on each surface it needs to cut or make only one topo surface
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
