Cutting Geometry with Void
humeyraborekci
Message 1 of 8
humeyraborekci
Hi everyone,
i'm trying to cut the these structures with a void, but it gives an error like this:
'can't keep elements joined'
i clicked 'unjoin' but it doesn't work.
I attached the *.rfa file and also screenshot of the regions I want to cut.
Thanks in advance.
Replies (7)
Message 2 of 8
hmunsell
take a look at this one....
Howard Munsell
Message 3 of 8
humeyraborekci
Thank you for helping.
Unfortunately, I can't open the model because I'm using the 2022 version.
Do you have a chance to send it in a previous version or I can try to upload newer release.
Message 4 of 8
hmunsell
sorry my bad..... my default it 23 currently. ill get that updated 😊
Howard Munsell
Message 5 of 8
hmunsell
give this a try.....
Howard Munsell
Message 6 of 8
humeyraborekci
 Hi @hmunsell,
Thank you for the model. I want to cut it like you did.
but I think you've made changes to the tunnel section. I attached the original section.
Can you please explain to me how you cut it? also do we have to change the tunnel section to make it work?
Message 7 of 8
hmunsell
correct, i just did a simple profile (didn't make those ledges), feel free to edit the void profile and change it as needed. they may not have the right wall thickness too..... i was just showing it could be done 😁
Howard Munsell
Message 8 of 8
humeyraborekci
I understand, thank you, but I'm trying not to make changes to the sections because we will take quantity take-off from this model.
