Cut Toposolid with void blends
a_simoc
a_simoc
Hello!
After a brief check around the forum for similar issues without any successful solutions, here I am with the following problem:
I'm trying to create a simulation for the phases required by the enlargement of a railroad embankment. Started out in Civil 3D from a survey, but the scarce COGO Points were producing a considerable errors in the TIN Surface and the overall result wasn't representing a realistic surface. So I decided to recreate the entire volume in Revit by manipulating it according to sections every 100m. The result is exactly what I was looking for, especially for such a small amount of work put into it. Now I have to simulate the benching (various numbers of steps cut into the OGL to support the next phase of filling the embankment), and the issue is that only extruded voids cut the Toposolid. Blends pop the error "Can't make cut-out." Tried it with Components as void blends, void swept blends, In-Place Masses (although it was harder to obtain two different profiles there). Nothing seems to work other than regular extrusions, which do not correspond to the required designed works. Is there any workaround, or correct way of approaching this?
Mark_Engwirda
@a_simoc Try using in-place solid forms and not voids to cut your topo-solid and then use the join tool to create the void in the topo-solid once your family has been created.
I have used in-place families for the example attached and then phased them to a later stage so they are not visible and don't schedule (yes its a work around)
I have used a topo-solid form and  generic form for both examples.
handjonathan
Hi @a_simoc
Thanks a lot for posting your question to the forums!   Has the solution suggested by @Mark_Engwirda helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
a_simoc
Thank you, Mark. Seems like there are still a few issues here and there, but it worked.
Job done. On to the next one.
