CUT ROOF / ROOF JOIN
HaleyAnneJLP
Message 1 of 9
HaleyAnneJLP
Hi!
I'm having a little trouble getting these different roofs to join correctly. I'm modeling pre-plans. See the picture, I need to remove the two roof corners that are visible through the ceiling on the porch, without that shift in the roof's alignment/flat plane. What's the best way to do this?
Thanks so much!
Replies (8)
Message 2 of 9
RDAOU
@HaleyAnneJLP
Did you try Opening By Face?
If you would attach the file for a closer look, maybe there is a better way to model the whole roof
Message 3 of 9
HaleyAnneJLP
Hi! Thank you, yes I did.  That dip in the ridgeline resulted from trying by opening by face and trying by adjusting the footprint.
Message 4 of 9
HaleyAnneJLP
Hi again!
I ended up getting near the desired outcome with a combination of roof cuts.
1) The first cut was a vertical opening that showed an error saying that it didn't cute anything but it allowed the wall to join to the roof.
2) A dormer cut to keep the angle of the roof pitch.
3) Edited the footprint of the perpendicular roof since the other join was lost.
It worked out okay - just had to click around for a bit. Any other tips are always appreciated!
Thank you!
Message 5 of 9
HaleyAnneJLP
PIC 3, 4, 5.
Message 6 of 9
RDAOU
@HaleyAnneJLP
Sorry, can't help you much without having to recreate the roof or you attaching the file. But you seem to have everything under control
Message 7 of 9
HaleyAnneJLP
Yeah, I think I just needed to work through it more - it's working out now.
Thank you!
Message 8 of 9
Is this pretty close to your condition?
4 roofs total  - 2 done  with Roof by Footprint using rectangular sketch boundaries, and 2 done with Roof by Extrusion using one sketch line each.  Join Roof and Dormer Opening tools created all the angles/openings.  Join Geometry tool hid the visible edge between coplanar roofs.
Message 9 of 9
HaleyAnneJLP
That is also super helpful. Yeah, I've just come to the conclusion that I had to poke around it for a while. Thank you!
