Topography doesn't respect Plan Regions.
You could set the View Range to above the topo and create a Plan Region with normal Cut Plane and View Range to reveal the building - you may run to issues with other elements acting weird to Plan Region such as Stair and Railing and whatnots so I do not recommend this.
I would turn off the topo for that view and overlay a transparent topo view on the same sheet.
