I am trying to set up a template that can be used for multiple projects regardless of the size.
One thing I need to do is do define a cut plane of 1500mm for all levels. I know this can be done manually for each level separately. However, I am wondering if it is possible to define the value as a default value that would be applied to all the levels? Is that possible?
