problems with drawing order
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
jlitwill14ZSXCA
512 Aufrufe, 8 Antworten
I am working on a floor layout and cannot figure out how to move text in front of other details.
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: jlitwill14ZSXCA
Cut and paste aligned in place the text.
Nachricht 3 von 9
jlitwill14ZSXCA
als Antwort auf: ToanDN
I am very new to Revit and don't know what that means
Nachricht 4 von 9
syman2000
Are you using model text? Model will always hide behind detail/annotation objects. So you may want to use Annotate>text.
Nachricht 5 von 9
jlitwill14ZSXCA
I have text both in front and in back and i don't know how to control it.
Nachricht 6 von 9
RDAOU
Select the text and look at the ribbon >>> look for the scissor tool that is cut...after u cut, there is a paste tool with a drop down menu...select paste aligned same place or current view
Nachricht 7 von 9
jlitwill14ZSXCA
that didn't work, the furniture is still in front of the text
Nachricht 8 von 9
RDAOU
Try to select the text and on the ribbon choose Pick New Host
You seem to be using model text and not annotations
Under annotation tab there is another form of text...try that one out too
Nachricht 9 von 9
jlitwill14ZSXCA
the annotation text worked, thanks for your time
