Hi @micah,
Hope you are well. Is it the same window family type as the others in your project which is functioning as expected? If it is the same window family type, what happens when you copy the instance to the desired location?
If the family type isn't exactly the same as the other windows or if there is a nested family in your window type, then it is important to set the family to Shared under Family Category and Parameters > Family Parameters > Shared if you need the cut plane to display as expected.
Here are two other links which you might find useful relating to the same possible problem:
Link One (cut plane in the View Range (family & nested families) need to match the project cut plane.)
Link Two
I hope this helps!
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome ⇘
