I have Revit 2017 and i'm trying to insert an image in a drafting view...
I insert the image... I save the file... close revit and when i open it again the image is gone... the only thing left is a box with and x on it. And no image.
So I tried it in another pc with Revit 2016, and it works fine there but not in my computer (revit 2017)
The image is a JPG format.
Help?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
That worked thanks!... But now I always have to put my images in a folder inside C: drive? ![]()
Is this supposed to be this way?
Thanks anyway ![]()
No you don't always have to save files in a folder in C:. It is just a test. I think there is some permission issues when files saved in one of the User's folder under Windows 10 (Desktop is one of them).
So you can create a Project folder somewhere outside of the C:\Users\. I suggested C:\Projects\ just for easy access but it's up to you.
Ok... ![]()
I actually don't like to poke around in the C: drive folder because that's where all program files are...
By inserting an image to revit, is it saving the image inside the project or not? i mean... will the image be embedded to the project file? If i but the project in a different computer will i be able to see the image?
@bluepantaleon02 wrote:
Ok...
There are a few folders you should stay away, such as anything with Program..., Windows..., Users... There are no harms to create new folders in C:\ but as I said, up to you.
It is supposed to work like that.
I had the same glitch on my home computer. But when I open my file in the office computer, I have no problem seeing the images. My office computer runs Windows 10 Enterprise and my home runs Windows 10 Home. May be that is the reason.
