Cut pattern of imported 3dm file (Site category) does not work..?
gsucci
gsucci
I have imported a 3DM file, and while I can assign to it a material, the cut patterns do not apply to it. Only surface.
I thought the Site category was cuttable?
What am I missing? How to control the cut graphics and appearance?
See project attached, and screen shots.
Thank you
Try Generic Models category.
RDAOU
@gsucci
Site works just fine
  • Edit the in-place
  • Explode the 3DM.
  • select the element assign a material normally using a parameter
  • Associate that parameter to the In-Place Site Family
  • Finish the in place component
This way you can change its material straight from the model without in-place editing
Edit: See GIF below
RDAOU
@gsucci
If you prefer it to be more generic, you can assign the exploded geometry to a Site Subcategory in lieu of assigning material parameters
gsucci
Thank you, I was hoping to avoid exploding imports...
Also, why is the surface patterns/appearance working but not the cut?
And, corollary question, where is the gray cut fill coming from?
Gio
RDAOU
@gsucci
Why exactly are you trying to avoid exploding 3dm file if I may ask? There is nothing wrong in doing that.
  • A 3dm falling under CAD does not mean it is a DWG (Even though, exploding DWG is also not always bad)
  • You can also import the 3dm Directly into the model and the family Category gets assigned to it without needing an in-place model.
  • The use an In-Place is the DWG impost workflow habit, promoted by many whenever CAD is mentioned
  • The advantages of importing into an in-place or a family .rfa in case of 3dm and .SAT are
    1. allows user to explode the form and convert to a are native Revit geometry
    2. gives  access to subcategories
    3. allows user to explode and assign parameter you can control...
    4. ie: you avoiding the explode means you are giving away the advantage.
Otherwise, use the RhinoInside.Revit plug-in from Rhino which will bring it into Revit and you wont have to worry if it is exploded or not exploded.
RDAOU
@gsucci
Missed your question why the cut pattern does not apply to imported category:
  • GO to visibility graphics and check what is available for override
  • When cut pattern is not available it means it is not accessible and the pattern is inherited from original object
Now see below the behavior of a 3DM imported directly into the projecy (no in-place and no Family)
