Cut Pattern Alignment
20mar013
20mar013
Wall cut pattern aligned in different direction for different walls, why?  How can i make all (similar) cut pattern alligned uniformly for all walls?
SteveKStafford
Make sure your wall's material cut pattern is assigned to a Drafting Pattern and that pattern is set to "Align with Element" in the pattern's properties.
Steve Stafford
RDAOU
@20mar013
Cut pattern are drafting patterns. To align all together in a plan view you need to set the pattern to "Orient to View"
While walls may have different orientation based on how they were placed, the plan view has 1 orientation  => if all are yousing the same pattern then all will align (See image below)
