@yangshilun2012 wrote:
hi, thx for your answering, the grid of surface is not a very regular, I didnot find a very related pattern for surface division, so I tried adaptive components.
and I have a little dynamo, can we achieve that?
That was pretty much clear in the image you attached to the original post. Working with i dividual adaptive instances will limit your options to either cut one by one or use dynamo to cut a bunch of instances intersecting the geometry of the void.
Not sure who is meant by we, but I'm pretty sure that with basic dynamo skills you can pull that one out. If you fail, there is a forum where you may beable to get help with it if you demonstrate that you have put in some effort...https://forum.dynamobim.com/
otherwise, you need to rethink your concept and modify the way you modeled the component to allow use of a pattern (either to make use of nodes required for repeaters or for applying a pattern based panels) ... Note: the pattern does not dictate the shape of the components. The pattern only drives the placement points (pattern based or adaptive).... the shape of the component itself can still be random...
