Cut Beam System in half so it makes two separate systems?
cadedu22
Message 1 of 11
cadedu22
How can I make such cut to Beam System, so it makes two separate systems instead of one ?
Like this:
Accepted solutions (4)
Replies (10)
Message 2 of 11
maYHS8K
I think you can copy+paste the system at the same location, and then modify each system to the meeting point.  Not sure if this is what you are looking for, but that's what I would do if I'm understanding the question correctly.
Message 3 of 11
cadedu22
Copy - past kinda works, I though may be there is a way to make simple cut in Beam System.
Message 4 of 11
RDAOU
@cadedu22
Once you have placed the system, u no longer need it...you can unpin the beams and cope them
Message 5 of 11
Clipboard Copy the Beam System and Paste Aligned to the Same Place. Then Edit and resize the Boundary of each System.
Message 6 of 11
cadedu22
@maYHS8K @barthbradley @RDAOU
Thanks Guys,
Then there is no option for simple divide for Beam System, beside good old copy/paste.
I also added "Ref Plane" in middle and then resize the Boundary of each System according it. It's a bit easier to align it then.
Message 7 of 11
@cadedu22
If there is a gap between the two systems then you can do this to keep them as one system.
Message 8 of 11
Why do you need two halves?  You could place a Beam down the middle (via 3D Snapping) and Cope all the Beams together (and zero out the Coping distance).
Middle Beam hidden in View:
Message 9 of 11
cadedu22
I needed this to make Balcony in middle of the roof. Otherwise if its huge building, there are a lot "Beam Systems" and it's becomes hard to manage all.
I was trying to find easiest way to do cuts like that.  🙂
Message 10 of 11
cadedu22
OMG, I never tried this, this is even better solution. It keeps all together as one system, and does what I want.
Message 11 of 11
RDAOU
@cadedu22
Then simply create an opening in the the sketch of the beam system similar to what you would do if you have a floor or a roof...you do not need to break up and split the beam system
