Customize Corner Mullion Problem
EfecanSoysal
EfecanSoysal
Hello! I have problem with creating my own custom corner mullion detail.
I am using rectangular mullion to create my corner mullion profile. But it's not fit properly in the corner. I need my custom corner mullions in the mullion category so modeling in curtain panel etc. doesn't work for me.
Is there any way to fix this problem in rectangular mullion or can I edit Revit's corner mullions? thank you.Capture.PNG
martijn_pater
Is it aligned to center?
EfecanSoysal
Hello, yes it is. If I delete this mullion you can see more clearly.
martijn_pater
Perhaps if you disallow join...? Other option could be to draw corner mullion as different family. It's a shame you still can't change corner mullion profile.
EfecanSoysal
Also If I connect curtain walls with manually it works for "Vertical Grids Continuous" but it's noo work for "Horizontal Grids Continuous".
