Custom Wall profile
Amiran_Janashvili
Custom Wall profile
Amiran_Janashvili
Hi everyone,
I am new in Revit community and have some difficulties with creating custom profile for walls. I want to create cross-section profile and draw several walls. I found out that it is possible to model a shape with "model in place" tool but this gives me only one element, while I need to draw several walls. Can anyone help?wall section.JPG
I need several walls with this cross-section.
hmunsell
Duplicate Post.....
https://forums.autodesk.com/t5/revit-structure-forum/wall-cut-profile/td-p/10104728
Howard Munsell
syman2000
Stack wall is probably the easiest like @ToanDN said. However you can use wall profile embedded into wall as well. As another alternative, you can also use curtainwall to achieve the same result. See attached
Amiran_Janashvili
I think embedded profile is exactly what I need. Can you tell me how to do it?
syman2000
You have to edit the wall, then go to section and then add the profile.
You can edit the profile width and height from the project browser>family
Amiran_Janashvili
Thank You!
