Custom Scale
Custom Scale
Message 1 of 22
Custom Scale
Firs time poster - long time Revit user
Downloaded Revit 2017 and want to be able to rename a custom scale. In previous versions I thought a dialog box popped up and we were able to rename the scale that way. I don's see this option in 2017.
Any help would be appreciated.
Cheers, Alex
Replies (21)
Message 2 of 22
L.Maas
No renaming scales. Always set the scale to custom for your view and enter an value
Or are talking about some different scale settings?
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 22
We're on the right track.
If I add a custom scale of say 1:60 but want the view to read 1"=5'-0", I always thought there was a way to rename the scale..
Message 4 of 22
L.Maas
What you are showing is a view title family. That, by default, reads the value from the view (as shown in my post above).
In the view title family it uses a label to read the view scale parameter. You could change your project to inches to see scales in inch formats.
Otherwise it would be editing the view title family, remove the view scale label and add your own parameter.
However you would have manually enter it in each view as it does not read the existing view scale.
Louis
Message 5 of 22
loboarch
When you choose "custom" from the scale list you get a dialog where you can specify a display name for the scale if you wish.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 6 of 22
L.Maas
Good one. Apparently never used the custom scale from that loacation, so never seen that dialog box
Louis
Message 7 of 22
Which version of Revit is this? I'm using 2017 and I choose custom it does not give me a dialogue box.
Message 8 of 22
L.Maas
It should be Ok. I am using Revit 2017 too. However, I never noticed it before, because normally I change scales in the properties window.
But to get this dialog box you have to do it from the view window (see screenshot, Revit 2017)
Louis
Message 9 of 22
Is there a way to add a custom scale to the line weights manager, or better yet to the entire project?  We are using 1:400 for our drawings and only 1:200 or 1:500 can be selected.  The lineweights do not seem to adjust accordningly ie it does not interpolate the values between the 1:200 and 1:500 when defining the 1:400 weights - and ends up looking much thicker than the 1:500?
Message 10 of 22
lionel.kai
related Revit idea: additional custom scale for Revit
Lionel J. Camara
BIM Manager at KAI Hawaii, Inc. - Structural and Forensic Engineers
Autodesk Certified Professional
Message 11 of 22
RobDraw
Why respond with the same post in three different threads when one thread of your own making would have been more than enough?
Thanks for the spam with my breakfast.
Rob
Message 12 of 22
antonjubani
Hi Is it possible to create a 1:1.5 scale or a scale to fit?
Message 13 of 22
rafael.pAGMAL
did you find the way? I'm looking for the same thing. I want to show details of a flashing profile in 2:1 or similar "larger than life" scales but seems to be impossible.
Message 14 of 22
rafael.pAGMAL
Not only it's impossible to use a "larger than life" scale like 2:1 but I also find it impossible to have a viewport in 9" = 1'-0", midway between  6" = 1'-0" and 12" = 1'-0" Apparently "custom scale" means something different for Revit programmers.
I try to input 9' - 1'-0" in the properties bar or in the scale button, and get "Enter and integer." message. Which BTW, it's completely unfriendly. Doesn't provide an example or even asks Please. Feels like an 80's interface instruction.
Message 15 of 22
RobDraw
Did you look up integer? Revit is telling you that is the only valid input. Trying anything else is futile.
Rob
Message 16 of 22
rafael.pAGMAL
Of course I know what an integer is and of course I understand that Revit won't let me use anything else, that's why I'm complaining, because it's a terrible idea. the "1" prefix shouldn't be fixed. If I could type 2=1 as a custom scale, they could have their beloved integer and we'll all be happy.
If I type "-2" as in Scale 1=-2 (note that -2 is an integer) then the error message conveniently changes to "Please enter an integer between 1 and 24000". (note the different tone) Why not using the same error message as default? this program is ridiculous.
If they're limiting us to a short list of scales, it's not "custom scale".
Message 17 of 22
RobDraw
That's a matter of opinion. Have you tried posting your thoughts in the IDEAS forum?
Rob
Message 18 of 22
lionel.kai
Some related ideas:
Lionel J. Camara
Message 19 of 22
lionel.kai
@rafael.pAGMAL I'm just curious what version of Revit you're using? When I tried testing the -2, it doesn't give me any error message (just closes when I click OK in the Custom Scale dialog) but doesn't accept the change (keeps the original value). I tested 2018, 2020, and 2022. I also tried 25000 and 50000 (in 2020) and it seems to be fine with that...
Lionel J. Camara
Message 20 of 22
rbasirat-wbi
Observer
Observer
I have a question. How we can add a custom scale to dropdown menu in Revit?
