Custom Railing
Custom Railing
bim360SU4E5
Custom Railing
bim360SU4E5
Hi Revit Masters!
I encounter a problem using Rail Structure. Hoping you can suggest some other way do it? I want the rail to be in RED pattern not a default straight line. (see Snip)
By the way rails are profiles.
Mike.FORM
No real easy way to do this in the railing family itself.
If the railing is just curved rails (a 3D view would help understand the railing patterning) then make the rails from an in-place family using a sweep.
If the riling has a panel in addition to the rails then make the railing using curtain wall and a custom panel that has the curve in it.
bim360SU4E5
Thanks @Mike.FORM for that comments, Appreciated a lot. However model in place would be a last option as these rails having a different elevation also. But I like the idea of having as a curtain wall.🙂
Model the Cabling as Baluster Panels
bim360SU4E5
This is cool @barthbradley! Appreciated Man!
